There are a few layers to this. I will start with Newtonian physics, which addresses your question about who accelerates, and then switch to general relativity for the answer which matches the tags you put on the question.
The answer of "does the earth accelerate towards the object or does the object accelerate to the earth" is a matter of book-keeping. What frame of reference are you in? Newton's Law of Universal Gravitation, $F=\frac{GMm}{r^2}$, is a law that applies in an inertial frame. In this frame, both objects accelerate towards each other. Their relative acceleration is the summation of these accelerations caused by equal and opposite forces. I highlight "relative" because that's a key word for your question. The acceleration you are interested in talking about is a relative acceleration between the Earth and the object.
That being said, remember that this motion is more complicated. In an inertial frame, the Earth is hurtling around in an orbit around the sun in an ellipse, and the object is hurtling around on a wibbly-wobbily orbit which is the composition of the motion around the sun and the motion around the Earth.
If we view this in an Earth-centric frame, such as Earth Centered Earth Fixed (ECEF), the story is different. In this frame the Earth is not accelerating. It's position is always (0, 0, 0), which means its velocity and accelerations are also zero. In this frame, the object is doing all of the accelerating.
But if I may be exceedingly pedantic, to avoid confusion, you cannot technically apply Newtons Universal Law of Gravity here. This is not an inertial frame. Remember that in the inertial frame that we started with, the Earth was being pulled on by the object, and thus the Earth was accelerating. Since the Earth is accelerating in an inertial frame, the ECEF frame cannot be inertial. Practical physics people will ignore what I just said. The accelerations of the Earth due to the object are so astonishingly slight that, for all intents and purposes, we can treat it as if it were zero, and the Earth was in an inertial frame. I make this distinction because in any textbook, you will see applications of Newton's Universal Gravity in the ECEF frame. It's a reasonable assumption. But if you start to try to come up with thought experiments that push the bounds, you will eventually come up with one that is so tortured that this distinction becomes the resolution of the paradox in your head. In physics, we like to say that this assumption is valid when $m \ll M$. It is valid when the mass of the object, $m$, is much less that the mass of the Earth, $M$. That notation is used when the difference is so substantial that it's reasonable to pretend one of them is either 0 or infinity. How big is "substantial?" Depends on the problem you are solving. If you're measuring with a yardstick, something may be insubstantial but become substantial when you start measuring with a micrometer.
And of course, you can flip this around. You can look at an object-centric frame. In this case, the Earth is the thing doing the accelerating. However, unlike the ECEF case, in this case it is unreasonable to hand-wave away the non-inertial nature of this frame. Most of the Earth's acceleration comes from the fact that the equations of motion in this object-centric frame are quite different from $F=ma$. They have all sorts of other terms like centrifugal terms and Coriolis terms. (two terms that arise in rotating frames that are reasonably easy to stumble through the math for). In this frame, it's not useful to say that the acceleration is due to the forces of gravity. The accelerations are mostly due to your chosen frame of reference (which just happens to be a frame we calculated by applying gravity in an inertial frame and mentally attaching the frame to the object)
Phew! That was a lot, given that everything above was Newtonian, and your question was tagged for GR. However, I have seen many people stumble because they didn't learn all of those steps and tried to apply the equations intuitively in non-intuitive situations. The above was very pedantic, but it captures things that are often hand-waved away.
The GR story is actually the simple one in freefall. The answer is neither. Neither object is accelerating in freefall in GR, so it's moot to ask which one is doing the acceleration. In GR, both the Earth and the object are moving along their world-line, a geodesic in 4-D spacetime, at a constant speed. If I phrase it incorrectly but perhaps more impactfully: both objects are moving in a straight line in 4-D spacetime. That statement is incorrect, because the concept of straight line is a bit non-sensical in a curved spacetime. That's why we use a mathematical term like "geodesic" rather than a simpler term like "a straight line." This is the message Veritasium was trying to get at in his infamous YouTube video on the topic. The argument is that gravity is not a force, per se. Instead, it is the product of the painful reality that our 3-D world does not have any inertial frames... it does not technically follow Netwon's laws. They could be thought of as ficticious forces, just like the centrifugal force that "pulls" you towards the side of your car while aggressively cornering. It's just such a prevalent ficticious force that it took a few hundred years to realize it wasn't a real force!
If the object is not in free-fall, then we do indeed say that the object has an acceleration in all inertial frames. That acceleration is not due to gravity. The acceleration is due to the electrostatic repulsions between the atoms in the surface of the Earth and the atoms at the surface of the object. In GR terms, that is a true force, and causes a true acceleration in the 4-D spacetime sense.
For most scenarios, you can ignore everything I just said after, "The answer of "does the earth accelerate towards the object or does the object accelerate to the earth" is a matter of book-keeping" in the second paragraph. For most real life practical situations, the non-inertial and/or relativistic effects are so astonishingly slight that you'll still get a sufficiently right answer, even if you didn't model them. The effect are typically way smaller than your measurement errors in the first place. However, if you start going fast, like a satellite, you increase the likelihood that these effects start to become meaningful. At this time, you have to step up the fidelity of your calculations, and start admitting that these effects take place.
