I am failing to understand how, if entanglement does not violate relativity, then reality can still be not super deterministic.
For the purposes of this question, let’s assume that the many worlds theory is false. Let’s also assume that there is no non local deterministic theory that explains QM, such as bohmian mechanics, since it explicitly violates relativity and posits non local influences between entangled particles.
The “standard” interpretation now says that there are “non local” correlations but without relativity being violated, and thus all influences are local. But if all influences are local, then how is this any different from superdeterminism where you posit hidden variables that predict both the measurement outcomes and measurement choices in such a way that they always result in the correlations predicted by QM, without any faster than light influences?
Unless you deny an objective reality (which seems to be against the very foundations of the scientific method), it seems that there is no way out except superdeterminism. This answer here also details why denying reality still does not save locality. And yet, superdeterminism is considered wildly implausible, but “relativistic” explanations of entanglement are not considered implausible. What’s really the difference? Without non local interactions between particles, it seems very “conspiratorial” for particles to still be correlated to each other even if they were separated by light years, the same way it seems conspiratorial in superdeterminism.
