I ran some numbers using the relativistic longitudinal Doppler effect formula $$\lambda_r = \sqrt{\frac{1+\beta}{1-\beta}}\cdot\lambda_s$$ where $\lambda_s$ and $\lambda_r$ are source and received wavelengths respectively, and $\beta = v/c$. Then I plugged in the wavelength of a red laser (630 nm) for $\lambda_s$ and solved for $v$, which gave me a result of $v=0.238c$ for the recieved wavelength to enter infrared territory, which doesn't seem that high (even though it's more than 20% lightspeed). So I would like to know if something like this has ever been observed or if it's even plausible.
Asked
Active
Viewed 2,673 times
36
Yes, of course. That is one of the main reasons that the James Webb Space Telescope focuses on the infrared part of the spectrum - galaxies at high redshift emit very little light in the visible part of the spectrum.
The redshift (in astronomy) $z$ is defined such that (in your terminology) $$\lambda_r = (1 + z) \lambda_s $$
Galaxies have been found with $z=10$ and upwards now, so for example, an emission line at 630 nm would be observed at 6.93 $\mu$m.
ProfRob
- 141,325
