I'm goofing around with the Android's API(not really important, I don't think). Anyway, I noticed in one particular corner of my room I'm getting a consistent reading of >100 mT on the phone's magnometer. It only seems to be occurring in this one object, but it has been consistently present for at least 2 weeks now. Everywhere else the readings seem typical, high near electronics, matching expected ambience elsewhere. Of note, the reading seems to be right next to or colocating a stainless steel book case. I've verified there are no plugged in electronics on this shelf. I've done my absolute best to isolate any potential "charging" of the metal shelf and to the best of my knowledge the shelf should be at ground.
I'm finding the readings to produce localized maxima near the meetings of the horizontal and vertical sections of the "book case", all maximum readings >150 mT, with localized minima at the vertical mid points. The orientations of the maxima do not seem to be aligned, though I have not fully mapped out their directions, only noting they're "not the same direction" and >150 mT.
At least by hand, I can detect no attraction to iron anywhere on the shelf itself. A comment indicated I should probably be detecting noticeable forces at these levels. The field attenuates to ambient at about ~50 cm, observationally the vertical separation of the shelves.
The horizontal shelves seem to be insulated from the vertical structure.
I'm curious. I've never seen or encountered something like this.
Questions; I don't think an EM standing wave could "magnetize" a metal shelf in such a way, but maybe?
As pointed out, this is a pretty high field that seems to have a span of the case, on the meter by meter scale. I'm struggling to come up with an explanation for what I'm seeing and really just want to better understand what/how could be causing this.
If necessary, I could provide an illustration better demonstrating my observations, but the description should be good enough.
