Lagrangian Approach for point-particle motion
Consider a point particle with mass $m>0$ moving along a worldline $x^\mu(\lambda)$ where $\lambda$ is an arbitrary parametrization. The action principle in the Lagrangian formulation of the problem is
\begin{equation} \begin{aligned} S&=-m\int d\tau\\ &=-m\int \sqrt{-g_{\mu\nu}\frac{dx^\mu}{d\lambda}\frac{dx^\nu}{d\lambda}}d\lambda. \end{aligned}\tag{1} \end{equation} So we get a Lagrangian function $$L=-m\sqrt{-g_{\mu\nu}\frac{dx^\mu}{d\lambda}\frac{dx^\nu}{d\lambda}}.\tag{2}$$ The euler-Lagrange equations give the dynamics for the arbitrary parameter $\lambda$, which are \begin{equation} \frac{D}{d\lambda}\frac{dx^\mu}{d\lambda}-\kappa \frac{dx^\mu}{d\lambda}=0.\tag{3} \end{equation} Here, $$\frac{D}{d\lambda}=\frac{dx^\mu}{d\lambda}\nabla_\mu\tag{4}$$ is the covariant time derivative and $\kappa$ measures the failure of $\lambda$ to be an affine parameter of the worldline $x(\lambda)$
\begin{equation} \kappa\equiv \frac{1}{\sqrt{-g_{\mu\nu}\frac{dx^\mu}{d\lambda}\frac{dx^\nu}{d\lambda}}}\frac{d}{d\lambda}\sqrt{-g_{\mu\nu}\frac{dx^\mu}{d\lambda}\frac{dx^\nu}{d\lambda}}.\tag{5} \end{equation} This equation can also be rewritten in terms of the proper time parameter $\tau$, in which case we simply get \begin{equation} \frac{D}{d\tau}\frac{dx^\mu}{d\tau}=0.\tag{6} \end{equation}
The important takeaway is that the action principle is explicitly reparametrization invariant and the equations of motion are obtained in terms of an arbitrary parameter $\lambda$.
Hamiltonian Approach for point-particle motion
We can also write down a Hamilton principle
\begin{equation} S=\int p_\mu dx^\mu-\int H ds\tag{7} \end{equation} where the Hamiltonian function is \begin{equation} H=-\sqrt{-g^{\mu\nu}p_\mu p_\nu}.\tag{8} \end{equation} In this case, Hamilton equations are
\begin{aligned} \frac{dx^\mu}{ds}&=\frac{p^\mu}{\sqrt{-g^{\mu\nu}p_\mu p_\nu}},\\ \frac{Dp_\mu}{ds}&=0. \end{aligned}
From the first equation, it is clear that $s$ is proper time, since $\frac{dx^\mu}{ds}$ is automatically normalized. From this, I conclude that:
When I wrote Hamilton's principle, I fixed the reparametrization invariance and I chose $s$ to be proper time.
Hamilton equations are then derived directly in proper time.
Question
Am I understanding correctly that the Hamiltonian approach loses reparametrization invariance and expresses dynamics directly in proper time? As opposed to the Lagrangian formulation, which preserves reparametrization invariance and gives the Euler-Lagrange equations in an arbitrary time parametrization.
Extra comments
I know that if one starts from the square root Lagrangian and tries to derive the Hamiltonian formulation using a Legendre transformation, one gets $H=0$ identically. I also know that this is because the Lagrangian formulation is reparametrization invariant. I'm not sure if this relates to my question or not, it probably does!
I know there are several questions on this forum about the Lagrangian/Hamiltonian formulations for a point particle in General Relativity, but I haven't seen the question of which time parameter each formulation uses, specifically.
