Here is what I mean:
In Lagrangian mechanics, we have the equation $$ \frac{\mathrm{d}}{\mathrm d t} \frac{\partial L}{\partial \dot q_i} = \frac{\partial L}{\partial q_i},\quad i = 1,2, \cdots, n. $$ and, a cyclic coordinate is the one that is not explicitly included in $L$: e.g., if $q_n$ is a cyclic coordinate, then $$ L = (q_1, \cdots, q_{n-1},\dot q_1, \cdots, \dot q_{n-1},\dot q_n), \quad \text{and thus}\quad \frac{\partial L}{\partial q_n} = 0. $$
And what I am curious about is: whether there is a Lagrangian system that essentially has no cyclic coordinates.
"Essentially" means that for any general coordinate system we use, the expression of $L$ contains no cyclic coordinate. This excludes the case of, e.g. the case of Kepler's two body problem, which has cyclic coordinate in Cartesian coordinate system, but have cyclic coordinates in polar coordinate.
If the answer of this question is YES, then furthermore, I am curious what if we limit to the "local" case: we do not search for the coordinate that can cover the entire configuration space, but instead, only consider a local coordinate around a general point, so is there any Lagrangian system that essentially has no cyclic coordinates even we take the local coordinates into consideration?
Editted on Dec 15 2024:
Thanks for @Eli 's reminding. I realized that I need to clarify this:
I assume that $L$ is autonomous (time independent), i.e. it is $L(q, \dot q)$ not $L(q, \dot q, t)$, so that time evolution is a symmetry, and energy $E_L = \sum_{i} \dot q_i \frac{\partial L}{\partial \dot q_i} - L$ is conserved. I want to know whether there is some $L$ that has no other continuous symmetries other than this one.
