During the introductory class on Hamiltonian mechanics after we had learnt the Lagrangian formalism, our professor said
"We cannot use Lagrangian mechanics to find the state of a system at any particular instant (he did not give any explanation), so that is why we use Hamiltonian mechanics."
But I think he could be incorrect, because when I did problems using Lagrangian as well as Hamiltonian I could find the generalized coordinates as a function of time. Can anybody explain where is the conceptual loop hole?
  1. OP's professor is possibly referring to the fact that the stationary action principle is a boundary value problem (BVP) [as opposed to an initial value problem (IVP)].
    In contrast, EOMs together with initial conditions (ICs) can in principle be integrated from an initial time to find the trajectory as a function of time.
  2. The issues of ICs vs. BCs for the principle of stationary action are already covered in this & this related Phys.SE posts and this related Math.SE post.
The action principle and the Lagrangian give you the equation of motion. The EOM tells you which states of the system are possible. By applying conditions, for example initial ones, a subset of these states is selected. The boundary conditions of the action principle are unrelated to the conditions imposed on the solution of the EOM.
As far as I understand the question, the Hamiltonian method assumes the EOM as a starting point. This approach is part of the Lagrangian approach.
my2cts
  • 27,443
