If you had a wheel filled with air vertically half inserted in water tank would it rotate through the buoyance made by gravity pushing pressure on the water making the density of the water more than the wheel?
i believe in the laws of physics and have read them but it still feels like it could work, because of the difference in density between the water and the wheel cycle submerging in and out the water.
I have debated with ChatGPT about it and it keeps saying that it would stop through friction but what I don't understand is why it would then have even initially started rotation and then just go to a stop rotation that seems weird as it started when not in motion
anyways I would like a clear explanation about this
better explaination: have a hollow wheel that gets more thin making sharp edges made of light but durable material pump it fully up with air
make a precise gap where the half of the wheel fits in the water container
pierce the wheel in the middle with rods attached to the water container allowing loose rotation of the wheel
