Newton's first law is often said to define what an inertial frame is - namely, a reference frame in which a body not acted on by a force will move with constant velocity. In other words, a frame where the first law holds.
However, this raises the question of what is meant by "not acted on by a force" and more generally how and what we define to be a force. Suppose you are floating in space with just one other object nearby. The object is at rest relative to you, and so you determine that your frame is inertial. Now suppose the object starts jiggling about in a seemingly arbitrary way. You have at least these options :
  1. You can say that you are no longer in an inertial frame, but instead being accelerated every which way, and that is why the object appears to move. (Fictitious forces).
  2. Or you can say that you are still in fact in an inertial frame, and the object is now moving because of some time dependent forces that started to act on it. Perhaps even after observing the object's motion for a long time, you would be able to describe the motion, and hence these forces, quantitatively.
Of course when there is more than one object moving around, it might be simpler to choose 1 over 2, for calculation purposes. But if so, then the determination of whether you are in an inertial frame or not is not an objective fact, but rather a subjective convention that you choose to employ for simplification of your calculations. What then, is the objective content of the first law?
Joey
  • 29
Newton formulated the first law in this way:
"Every body perseveres in its state of rest, or of uniform motion in a right line, unless it is compelled to change that state by forces impressed thereon." (I.)
I do not think there was any mention of "inertial reference frame" in Newton's book (but I do not know for sure). Newton used the notion of absolute space instead. The first law was mentioned to apply with respect to this absolute space, and by necessity also to all reference frames that are in uniform motion with respect to it.
If we do not accept this setting of the first law (as Ernst Mach, who criticized the notion of absolute space), the first law is not always valid. For example, an observer on a roundabout observes that objects on ground move with acceleration without presence of any corresponding impressed forces.
So in order to preserve the coherence of Newtonian mechanics without absolute space, the notion of inertial reference frame was introduced, which is a notion more close to the principle of relativity. "Inertial frame" is a rigid body such that in its coordinate system the first law is valid.
... the determination of whether you are in an inertial frame or not is not an objective fact, but rather a subjective convention that you choose to employ for simplification of your calculations.
One cannot determine with certainty whether he is in an inertial frame or not. By definition, that would require checking that all free bodies move exactly recti-linearly, which is impossible.
In the relativistic view, the content is that the inertial frame exists, or at least, from pragmatic point of view, that frames close to inertial can be found and usefully adopted.
So far the experience shows that the assumption of inertial frame can be always made with success. With varying degree of accuracy, it can be the frame of the Earth, or frame with origin in the center of the Earth-Moon system, or the Sun; all with fixed orientation with respect to the stars. We do not know certainly that such frames are exactly inertial, most probably they are not, but assuming that they are, we obtain very reliable results; their deviation from perfect inertialness is negligible.
Say you wanted to build a physics model in a computer program. JavaScript is an easy example, here is an object with an x coordinate and a velocity along the x dimension and that is dx. Your program is then something like
object1 = {x: 0, dx: 3} ;
while (true)
    object1.x = object1.x + object1.dx;
So that covers the first law of motion.
Without that, the second law wouldn't really do anything, would it? You could apply force (which changes dx) but without inertia, what's the point?
I don't know what you mean by "objective content". But I can tell you what it seems Newton thought the content was. At the time Newton wrote, the first law was a repudiation of the Aristotelian view that force was necessary to maintain an object's motion.
From the Wiki article on Newton's laws:
The ancient Greek philosopher Aristotle had the view that all objects have a natural place in the universe: that heavy objects (such as rocks) wanted to be at rest on the Earth and that light objects like smoke wanted to be at rest in the sky and the stars wanted to remain in the heavens. He thought that a body was in its natural state when it was at rest, and for the body to move in a straight line at a constant speed an external agent was needed to continually propel it, otherwise it would stop moving. Galileo Galilei, however, realized that a force is necessary to change the velocity of a body, i.e., acceleration, but no force is needed to maintain its velocity. In other words, Galileo stated that, in the absence of a force, a moving object will continue moving. The tendency of objects to resist changes in motion was what Galileo called inertia. This insight was refined by Newton, who made it into his first law, also known as the "law of inertia"—no force means no acceleration, and hence the body will maintain its velocity. As Newton's first law is a restatement of the law of inertia which Galileo had already described, Newton appropriately gave credit to Galileo.
It seems that, in talking about the first law only being correct in inertial reference frames, you have already accepted the revolutionary content of the first law: the very concept of inertia.
Flavin
  • 629
