A quasistatic process is a process where all intermediate states are in equilibrium. A reversible process is a process where no entropy (of the universe) is generated (and thus can be reversed to its original state). Every reversible process is quasistatic but not every quasistatic process is reversible. However, can the difference also be explained with the following statements:
- For every quasistatic process the system is in internal equilibrium (with itself).
- For every reversible process the system is in both internal equilibrium and in equilibrium with the surroundings.
Examples: If a gas expands by suddenly removing a force on a piston, there is a difference in pressure inside the gas, hence it's not in internal equilibrium so it's not quasistatic (and also not reversible).
A gas is expanded by removing the force on a piston, however due to friction this expansion happens slowly. The gas is in internal equilibrium, but the pressure inside the gas is not equal to the pressure of the surroundings, so this process is quasistatic but not reversible.
The force exerted on a piston is very slowly decreased in such a way that the process is isothermal (due to the heatflow from the surroundings). This process is quasistatic and also reversible (the pressure in the gas is equal to the "pressure" exerted by the surroundings and the temperature of the gas is equal to the temperature of the surroundings).
Are my statements correct, or can you come up with a counter example?
