I was studying Newton's laws(law2) and encountered a problem,
In my textbook(Selina publications),
it is written:
Force applied is directly proportional do the rate of change of momentum, and the units are chosen as such that the constant of proportionality is 1
so with the correct choice units and according to my text, $$F = \frac{\Delta p}{\Delta t}$$
Now as $p(t) = m(t) \cdot v(t)$ where $m$ and $v$ and mass and velocity functions of time[dont interpret dot as dot product, it is a scalar product],
and also replacing concrete $\Delta$ changes to infinitesimal $d$ changes, and using all of these facts ,
$$F = \frac{d}{dt} (m(t)v(t))$$ and using the chain rule, $$F = m \frac{dv}{dt} + v \frac{dm}{dt}$$
Now here, the problem arises, I also have a Physics handbook by Yavorsky and Detlaf, in there, [2.8.1]
$$\frac{d}{dt}(mv) = F + v_1 \frac{dm}{dt}$$
where $F$ is the resultant of all the forces acting on the body $v_1$ is the velocity of the added masses before joined to the body(if $\frac{dm}{dt} > 0$), or that of the detracted mass after being separated from the body (if $\frac{dm}{dt} < 0$)
here, in one side(The first cited equation )$F$ is directly equal to $\Delta p$ while on the other(the handbook cited equation), there is an extra term with $F$ to equate it with $\Delta p$. Can anyone tell me which one is right??
I am a ninth grader, and my knowledge may be incomplete in some areas of physics, so please answer right from the basics...
