-1
Why is electric flux through any closed surface $q/\epsilon_0$? In schools we are only taught of its simplest case, i.e. flux through a sphere with charge centered at origin. And then it is generalised to all closed surfaces. Is there really any proof of flux through all closed surfaces.
N.G.Tyson
  • 802
A simple derivation would be this one. Suppose you have a single charge $q_i$ inside a closed surface.
The flux across a closed surface is: $\Phi=\oint\vec{E} d\vec{A}$
Coulomb's law says: $\vec E=\frac{q}{4\pi\epsilon_0r^3}\vec r$
In this case, it means that the flux is: $\Phi_i =\oint \frac{q_i}{4\pi\epsilon_0r^3}\vec r d\vec{A}$
If you solve the integral, it yields: $\Phi_i=\frac {q_i}{ \epsilon_0}$
By the superpositon principle: $\Phi=\frac {Q}{ \epsilon_0}$
jinawee
  • 12,675
  • 60
  • 102
