I wonder when a particle undergoes free fall onto Earth's surface, does all components of its proper acceleration vanish so that the magnitude of proper acceleration is zero? If a charged particle undergoes "free fall" (uniform acceleration) with acceleration of $g$ in electric field, does all components of its proper acceleration also vanish in this case? If not, why?
The components of 4-acceleration $A$ are
$$A^\lambda = \frac{dU^\lambda }{d\tau } + \Gamma^\lambda {}_{\mu \nu}U^\mu U^\nu$$
where $U$ is 4-velocity. Based on my understanding, the magnitude of $A$ gives proper acceleration: $\alpha=||A||$. So I must show that $||A||=0$ during free fall. I suspect that during free fall, it must be the case that $\frac{dU^\lambda }{d\tau } = -\Gamma^\lambda {}_{\mu \nu}U^\mu U^\nu$. I am not sure why it is true.
Jimmy Yang
  • 1,075
A particle in free fall performs geodesic motion, so that its equation of motion is given by the geodesic equation, which is (in local coordinates): $$ \frac{d^2X^\mu}{d\tau^2} + \Gamma^\mu{}_{\rho\sigma}\frac{dX^\rho}{d\tau}\frac{dX^\sigma}{d\tau} = 0 $$ If we now call the worldline tangent $\frac{dX^\rho}{d\tau} = U^\rho$, we immediately end up at your statement. The point is that in general relativity, proper acceleration denotes the deviation of a particle's worldline from geodesic motion - this is the general relativistic analog of Newton's first law, which assumes the flat-space case in which all geodesics are straight lines. "Free fall" in this case means exactly that: The particle is "free" in the sense that no external forces act on it, so that it is in an inertial frame.
paulina
  • 3,488
