There are many cultures around the world that have traditions of chocolate coins around Christmas time, mine included. Recently I wondered if it was possible to compress chocolate to give it the same density as a real coin (which are mostly made of copper I believe, though the exact composition is not that important). There is no real purpose to this question, other than entertaining the idea that you could trick people into thinking these are actual currency instead of the chocolate kind.
Assuming a coin is made of 100% copper, it would have a density of about 8960 kg/m$^3$, whereas chocolate has a density of about 1300 kg/m$^3$. This means you would have to compress it to about 1/7th of its original volume. Since chocolate has a non-zero compressibility, I figure it is possible to get it to that density, but would the chocolate still retain similar physical characteristics during the process, or would the pressure needed cause other effects that make this impossible? I have little experience in the subject of material science, so I wasn't able to get to good information regarding chocolate under pressure, mostly about effects of chocolate on blood pressure.
Any chance someone has a hydraulic press to do a taste test afterwards?
Edit: Source for the density of chocolate https://www.density.co.uk/documents/Density-of-Chocolate.pdf
