$\mathbf{Background:}$ Consider a free scalar field $\phi$ ($\mathcal{L}_0 = \frac{1}{2}\partial_\mu \phi \partial^\mu \phi + \frac{1}{2}m^2 \phi^2$).
In the Hamiltonian viewpoint, this system has a Hilbert space $\mathcal{H}_0$ (the Fock space). We can write down a resolution of the identity in $\mathcal{H}_0$ (in the Schrodinger picture):
$\begin{align} I = |0 \rangle \langle 0 | + \int dp\ |p \rangle \langle p | + \frac{1}{2!} \int dp_1 dp_2\ |p_1 p_2 \rangle \langle p_1 p_2 | +\ \cdots \end{align}$
$\mathbf{Question:}$ If we add an interaction term to the Lagrangian (such as $\lambda \phi^4$), is $I$ still the identity operator in the new Hilbert space $\mathcal{H}$?
(To be clear, I mean exactly the same $I$, with the free vacuum and free particle states.)
$\mathbf{Motivation:}$ The analogous thing holds in QM. A non-relativistic particle moving in a potential $V$ has a Hilbert space $L^2({\mathbb{R}})$, so by Fourier transform, $\int dp\ |p \rangle \langle p |$ is a resolution of the identity. (Where $\langle x | p \rangle = \frac{1}{\sqrt{2\pi}} e^{i p x}$ are free particle states.) The Hilbert space is the same regardless of $V$.
marlow
  • 281
Yes, that's still a resolution of the identity.
But knowing this isn't likely to make your life easier. The observable algebra for the free theory and the observable algebra for the interacting theory are generated by unbounded operators. These algebras do not have the same domains of definition. The 'free-particle' resolution of the identity you wrote down is convenient when you're dealing with the domain where the free field operators have a well-defined action, but it's generally singular when you're trying to study vectors which live in the domain of the interacting field operators.
user1504
  • 16,959
