The second is defined as
I am confused as the hyperfine transition frequency is not fixed, i.e., it has a finite linewidth. The frequency is not well defined.
Is it because the linewidth is very small? If so, why is it small?
poisson
  • 2,185
The energy difference between every two atomic levels is a well-defined value, as those levels represent distinctive quantum states. So there is no problem with a statement that those two hyperfine levels in Cesium are separated exactly by ~$9.2$ GHz. So, in that sense, the transition frequency is fixed.
Of course, you are correct that observed transitions have their inherent widths that limit how precise one can lock their oscillator to the center of the transition. That width is inversely proportionate to the lifetime of a given state. However, in the case of magnetic dipole transitions (like the one in Cesium), the decay rate is extremely slow. I could not find an estimate for Cs, however, the other well-known similar transition - Hydrogen 21cm line has a lifetime of more than $10$ mln years. Assuming that the Cs is similar enough to the H, one can estimate that the lifetime of the clock transition is more than $10^4$ years (the decay rate is proportional to $\omega_0^3$) which corresponds to the linewidth of the order of $10^{-12}$ Hz. In that case, you are correct and the width of this transition is so small that it can be neglected.
In real applications, the width of the Cesium clock transition is mostly limited by technical difficulties and is below 10 Hz. Clocks are limited not only by the precision of their electronics or mechanical stability but also by background thermal radiation that disturbs atomic samples and also by the limited time that the sample can interact with interrogating fields.
The quality of a clock can be described by a $Q$ factor, which is a resonance frequency divided by its resonance width. Reducing observed linewidth in Cs further is very challenging. For this reason, right now the clock community is trying to use different transitions having significantly higher, optical frequencies (jump from GHz to hundreds of THz) to further improve our atomic clocks.
Noct
  • 747
