I was recently considering how to keep a super cheap ultrasonic range sensor safe from balls (or blocks, or whatever) going down ramps (or otherwise moving at high speeds) in a physics lab. It struck me that, if there were some solid that had a density identical to air, you could place a plate of it in front of the sensor to protect it, and it would not interfere with the sensor's measurements at all. Is such a solid possible?*
*I could, of course, use a laser range sensor and aim it through a slit... or tie a string to the ball, place my sensor farther away, use a sturdier sensor, send objects at it at lower speeds, put some sort of wire in front of the sensor close enough that it wouldn't be detected, etc. etc. etc. The real-life solutions to my problem are numerous: I'm asking about the crazy question that the problem prompted me to ask.
