I need to plot some electric and magnetic fields in 3D. Can anyone recommend a good program - something easy where I can just insert the vector field components?
Edit: I am plotting the E and B fields of a circularly polarized (finite) wave packet. I can provide the x, y, and z components of the vector field - I want to plot (draw) either a vector field with arrow length corresponding to field magnitude, or flow lines (field lines).
The other posts referenced do not provide assistance with this. This is not a duplicate question.
You can use matplotlib
import numpy as np
import matplotlib.pyplot as plt
from mpl_toolkits.mplot3d import Axes3D
fig = plt.figure() ax = fig.add_subplot(111, projection='3d')
x = np.linspace(-5, 5, 10) y = np.linspace(-5, 5, 10) z = np.linspace(-5, 5, 10) X, Y, Z = np.meshgrid(x, y, z)
U = X V = Y W = Z
ax.quiver(X, Y, Z, U, V, W, length=0.5, normalize=True)
ax.set_xlabel('X-axis') ax.set_ylabel('Y-axis') ax.set_zlabel('Z-axis')
plt.show()
Mathematica is an excellent software to full fill your needs. The manual of Mathematica will satisfy all your curiosity regarding plotting.
