Electric current can be defined on different levels. Firstly, let me restrict the discussion to classical transport, since things may get rather different in quantum domain, and bridging between classical and quantum descriptions of transport phenomena can be somewhat complex. (E.g., see a discussion in this answer.)
Boltzmann equation
On the classical level, the most complete description of electron transport is obtained using non-equilibrium statistical physics, that is Boltzmann equation for the destribution function of momenta/velocities and positions: $f(\mathbf{v}, \mathbf{r},t)$:
\mathbf{j}=\int d^3\mathbf{v} d^3\mathbf{r}\mathbf{v}f(\mathbf{v}, \mathbf{r},t).
Note that the distribution function is usually normalized to the number of particles, so the current is that of the whole system:
\int d^3\mathbf{v} d^3\mathbf{r}f(\mathbf{v}, \mathbf{r},t)=N
Hydrodynamic description
Hydrodynamic description is a simplification, which is obtained from the Boltzmann equation under the assumption of local thermodynamic equilibrium: that is, we assume that temperature, concentration, potentials and other mean and external variables vary slowly in space, so at every point the system can be described by a Boltzmann distribution. (See, e.g., the references in this answer for more details.)
We then arrive to usual hydrodynamic equations, among which we have Navie-Stokes equation and the continuity equation
\nabla\cdot \mathbf{\rho\mathbf{v}}+\frac{\partial \rho}{\partial t}=0
Thus, the current can be defined naturally as $\mathbf{j}=\rho\mathbf{v}$, where it is understood that the velocity and the concentration fields are related via the hydrodynamic equations.
Drude approach
Finally, the ad-hoc approach adopted in elementary texts is simply writing the current as $\mathbf{j} = \rho\mathbf{v}$, where the velocity is assemed some kind of mean "drift" velocity, determined by Newton-like equations of motion (see, e.g., this derivation). This intuitive approach was historically rather successful - see Drude model. It can be seen as a linearized version of the hydrodynamic model, which assumes constant electron density.
