I have been using results from this paper in calculations. In sections 2.4 and 3.4 they perform a canonical transformation into new coordinates consisting of constants of motion. They then construct an SL$(2, \mathbb{R})$ algebra that acts on these coordinates.
The canonical transformation for Schwarzschild $(r, \phi, p_r, p_\phi) \rightarrow (T, \Phi, H, L)$ is given by \begin{align} d T &= \frac{Hr^4}{\left(r^2-2Mr\right)\sqrt{\mathcal{R}(r)}}d r \\ d \Phi &= d\phi - \frac{L}{\sqrt{\mathcal{R}(r)}} d r. \end{align} where \begin{equation}\label{eq:HamSchw} H = \sqrt{\left(1-\frac{2M}{r}\right)\left(\frac{p_\phi^2}{r^2}+ \left(1-\frac{2M}{r}\right)p_r^2\right).} \end{equation}
We can then define a generator \begin{equation} H_0 = (H- \tilde{H}(L)) T \end{equation} where $\tilde{H}(L)$ is the Hamiltonian of the null bound geodesics \begin{equation} \tilde{H}(L) = |L|/ \sqrt{27M^2}. \end{equation} Now the number of orbits for an unbound geodesic can be calculated through the winding number $w = \Delta \phi /(2\pi)$. It can be shown that $\Delta \phi$ in the limit of bound null geodesics is given by $$\Delta \phi = \ln(R_{\text{min}}^{-2})$$ where $R$ is defined through $r = 3M(1+R)$. In this case $$\{w, H_0\} = 1/(2\pi).$$
In section 2.4 the authors claim that the group action on the observable $w$ increases it to $w+1$ (see eq. (2.71)). I am confused on how this group action is defined, as I am not used to their conventions. How is the group action here defined in terms of Poisson brackets?
This should be familiar to you from the first example of generators of transformations we usually encounter: The bracket between position $q$ and momentum $p$ is constant as $\{q,p\} = 1$, and momentum generates translations $q\mapsto q + c, c\in \mathbb{R}$ as the corresponding one-parameter group action.
You have a constant Poisson bracket $\{w,H_0\}$, hence $H_0$ likewise generates translations $w\mapsto w+ c$ in $w$ as the corresponding group.
Both of these are special cases of the general idea that for any phase space function $f$, the group action generated by it on any other phase space function $g$ is simply given by $\partial_\phi (g\circ\exp(\phi f)) = \{g, f\}$ where $\exp(\phi f), \phi \in \mathbb{R}$ is the flow of the Hamiltonian vector field of $f$. See also this answer of mine.
ACuriousMind
  • 132,081
