So that seems like a silly question but I can't quite rationalize something about it.
Electric field in between the plates of a capacitor is defined as E= emf/d.
A dipole antenna acts as a very strangely oriented capacitor building and releasing charge as voltage is applied and released.
A monopole antenna, acts as a capacitor with ground being the universe or very very far away. Still storing some charge and releasing it.
in all three of those applying a voltage creates an electric field around the wire and acts (to one degree or another) as a capacitor of sorts.
So why is it that no observable electric field is around say batteries. You can put the two positive terminals of batteries together no problem. But putting positive to positive would effectively divide by zero. E=emf/d d->0. Same with energized DC wires that don't have any current flowing through them. There's no repulsive force at all. But if they were both producing a positive electric field around themselves shouldn't they repel one another.
So here is the question. Is there an electric field around a DC energized wire that has no appreciable current flowing through it? If so why is there no interaction between it and other energized wires or plate? Do the charges just redistribute in a way that they aren't really pushing apart (lets face it there are a lot of available electrons present even in a positively charged anything).? This would imply that a flying charged particle will experience the field but that another energized wire would not. This is what I am thinking but I want someone with a little more understanding to correct me/enlighten me.
If "energized" means charged, then yes.
There is, but the charges involved must be very large or the distances between the charged wire and other object must be very small before these interactions become readily observable.
You can observe these interactions, with, for example, an electroscope.
The Photon
  • 29,651
