Warning I don't have a physics background, having said that I was recently looking into the sun's radiation energy entropy and I had a couple of questions.
So it is said that we can utilize the energy from the sun on Earth because of its low entropy. The entropy according to the second law of thermodynamics can be estimated as: $S=\dfrac{E}{T_{sun\_surface}}$ [1]
Now given that the energy received from the sun is exponentially proportional (inverse square law) to the distance from the sun, does it mean that the closer we get to the sun the higher the entropy of the energy of the sun would be? (because the E would get bigger and bigger)
Is this because the earth would heat up faster and faster the closer we get to the sun? what is some intuitive explanation of why this is expected to happen?
Asking because normally I don't see people giving distance as one of the major factors when they explain why the sun has low entropy, eg [2]
Edit: ok, so distance doesn't seem to matter. After reading [3] I would summarize the following based on my understanding: because the energy we receive from the sun is emitted by a much hotter surface (sun's) compared to the objects that receive it here on earth (eg 300K), as a whole is expected to be lower entropy (interesting note: the spectral radiance of the sun is set to maximize entropy given its temperature/energy given its similarity to blackbody radiation). since the sun's radiation displays similar characteristics to blackbody radiation and its surface temperature is high, its spectral radiance is more concentrated in the visible range. This combined with the fact that smaller wavelength radiation has lower entropy allows us to have more usable energy in the visible and near visible range, ie higher energy[4]. Some energies in the longer wavelengths may or may not be usable due to either low entropy or low intensity through the exergy definition
[1] https://ncse.ngo/creationism-and-laws-thermodynamics-0
The amount of radiant power that passes through this area is called the solar constant and is equal to 1373 Joules/second (Lide 2004-5: 14-2). In the absence of the earth's atmosphere, the entropy of this sunlight would equal this energy divided by the temperature of the sun's surface, known from spectroscopy to equal 5780 K. The result would give the entropy of this amount of sunlight as 0.238 J/K every second
[2] https://physics.stackexchange.com/q/399471
In contrast, the Sun's temperature is enormous—around 5500°C, which makes the denominator of the effective entropy term S=E/T quite small. Thus, it's not the energy of the sunlight that's particularly useful—it's its low entropy
[3.1] https://www.nature.com/articles/s41598-017-01622-6
[3.2] https://www.nature.com/articles/s41598-017-01622-6#Fig3
