Let us consider the $\phi^4$ theory, where $\phi$ is a real scalar field, such that the physical mass vanishes.
Is it true that the bare mass also vanishes?
MKO
  • 2,349
Assume spacetime dimension $2 \leq d \leq 4$. The $\phi^4$ coupling constant $\lambda$ has mass dimension $[\lambda] = 4-d$. The one-loop mass correction is linear in $\lambda$. Given the UV cutoff $\Lambda$, simply by dimensional analysis we can conclude that $m^2$ receives UV-divergent correction $$ \lambda(\Lambda^{d-2} + m^2 \Lambda^{d-4}). $$ Note that $\lim_{\epsilon \rightarrow 0} \Lambda^{\epsilon} \sim \log \Lambda$.
So, nope, generally the bare mass will contain the first term, which is independent of the renormalized mass $m^2$. You need to fine-tune the bare theory to get near the massless critical region.
Dimensional regularization is well-known to only pick up logarithmic divergence and completely ignores e.g. the quadratic $\Lambda^2$ term in $d=4$ in this case. It is true that in this case only the subleading term is important for the RG flow in $2 < d < 4$, and people often just merrily dim. reg. away. But do keep a record what you are sweeping under the carpet.
T.P. Ho
  • 777
