10
First off I am not well versed in physics, but as I understand things the second is defined by the ceasium fountain clock which is calibrated as follows How was the first atomic clock calibrated?. Now my question relates to how that relates to time measured by the everyday person. Some background:
  1. I am aware of GPS and the time dilation effect from geostationary orbit.
  2. There are leap seconds as the earth's orbit around the sun is not constant.
  3. Time measured in physics, for example the measurement in scientific experiments is different to the logging of time for financial transactions (for example stock trades), phone call logs etc. (or is it?)
  4. That (in the UK) a radio signal is transmitted with the atomic time encoded in the signal.
My question is how is are the world's atomic clocks continually calibrated to compensate for the vagaries of the Earth's rotation and orbit around the sun?
How does the orbit of our solar system affect the calibration of these clocks? i.e. does the Doppler effect, affect the continual calibration?
My question is how is are the world's atomic clocks continually calibrated to compenstate for the vargaries of the Earth's rotation and orbit around the sun?
They aren't. The atomic timescale is independent of the current rotation or orbit of the earth. Instead multiple clocks are compared against each other (compensating for things like different gravitational field strength and different rotational speed due to latitude). Poorly performing clocks can be detected and excluded. The remaining ones are, in a sense, "averaged together" and produce TAI.
There are leap seconds as the earth's rotation on its axis is not constant and UTC currently ties together both the rotation of the earth and atomic time. Because of this, we cannot exactly predict when leap seconds will need to be added (or subtracted).
There are other proposals that would decouple rotation from UTC to avoid some of the problems with leap seconds.
The orbit of the earth around the sun doesn't vary as much. The problem there is we like to count (tropical) years in integer numbers of days, and there is no exact ratio between the two. Calendars need to compensate for that, but the discrepancies of calendars are different than the problems of atomic time and earth rotation.
BowlOfRed
  • 42,997
  • 68
  • 123
13
Modern metrology supports the issues you address by having multiple time systems, each with their own peculiarities. Any activity that needs a clock to measure time chooses a time system which meets their particular needs.
Each atomic clock produces its own time system. Technically any clock produces its own time system, but the atomic clocks are particularly precise so we draw extra attention to them. Each clock has some drift associated with the imperfections in the hardware. It also has predictable drift based on its environment. In particular, each clock is at a different altitude, and thus by general relativity has a different rate of time passing.
The major owners of high-precision clocks (such as NIST) work together to produce a calculated timescale called TAI. TAI was a weighted average of the clocks, but in 1970 they added a correction to the output of all of the clocks to correct for the effects of general relativity. Thus now TAI measures time "at sea level," by applying correction terms mathematically.
Another time system, UT1, follows the rotation of the Earth. This speeds up and slows down due to complicated mechanics inside the planet. UTC adds (or removes) leap seconds to try to stay within 0.9s of UT1, but otherwise stays in time with TAI (1 UTC second = 1 TAI second). TAI, on the other hand, just keeps ticking, 86400 seconds every day.
Beyond that we have additional calculated time systems. There's barycentric time systems, such as those which calculate the passage of time with some object staying some great fixed distance away from the sun (the great distance avoids more time dilation issues).
There's plenty more beyond that, but that should provide context for the answer: we use the atomic clocks to come up with a meaningful time in TAI, and then we apply correction factors to convert a time into a time system which is appropriate for the task at hand.
Cort Ammon
  • 53,814
  • 103
  • 176
