The calculation of errors is important.
With the limited information that is given one can make an estimate of the error in the area by assuming the last digit in a length is in error by $\pm 1$.
However this example shows that caution must be applied when using the idea that the number of significant figures in the product cannot be greater than the number of significant figures for each of the quantities being multiplied together.
In the mathematical sense $98$ is a length given to two significant figures but when computing errors it is better to use the fractional error which in this case is $1/98$.
Using fractional errors shows that, although $98$ and $102% are quoted to differing numbers of significant figures, in terms of accuracy they are almost the same.
A simple estimate of the error is found by just adding the fractional errors and converting that into an actual error, eg $\pm \left (\frac {1}{98}+\frac{1}{213}\right )\times 208.74 \approx \pm 3$.
However this can be considered to be an overestimate as it assumes that both lengths are simultaneously maximum values or minimum values.
A better estimate of the error is $\pm\sqrt{\left (\frac{1}{213}\right)^2+\left (\frac{1}{98}\right)^2}\times208.74 \approx \pm 2$
You will note that in both methods the third figure in the product has some significance and so the value for the product should be quoted to three significant figures, ie $209\pm3$ or $209\pm 2$ depending on which method is used.
