Given a Lagrange density
$$\mathcal{L} = g^{ij} \phi_{,i} \phi_{,j} - V(\phi)\tag{1}$$
I have read (e.g. here) that the boundary term that occurs through variation of the action
$$ \delta I = \int_V dV \, \text{EL} \, \delta \phi + \oint_{\partial V} dS \, n^i \, \partial_i \phi \, \delta \phi\tag{2}$$
vanishes for Dirichlet conditions ($\delta \phi = 0$), for homogeneous Neumann conditions ($\mathbf{n}(\phi) = 0$) AND for their combinations, i.e. Robin conditions ($ a \phi + b \mathbf{n}(\phi) = c$).
It is easy to see how Dirichlet conditions and homogeneous Neumann conditions make the boundary integral vanish. However, I do not understand how Robin conditions achieve the same thing.
Octavius
  • 881
  1. As mentioned in the linked Phys.SE post there are 2 possible boundary conditions (BCs):
    • Essential/Dirichlet BC,
    • Natural BC,
    which can be chosen independently for each connected components of the boundary $\partial V$.
    The BC cannot change discontinuously within a connected boundary component since the field variables are usually assumed to be continuous/sufficiently differentiable due to physical reasons.
    However, if there is more than 1 connected boundary components, then combinations are possible: Essential/Dirichlet BC on some connected boundary component and natural BC on the rest.
    NB: The word combination should not be understood as a linear combination, cf. OP's question.
  2. Example: In OP's action (1), the natural BC is a Neumann BC. If we add a boundary term proportional to $$\oint_{\partial V} \!dS ~ \phi^2$$ to OP's action (1), then the natural BC becomes a Robin BC.
