In other words, when a particle's mass increases significantly as it approaches the speed of light (c), does its influence on gravity increase, and if so, does it increase proportionally?
Xonatron
  • 349
  • 14
The mass (the true mass) is an intrinsic property of a body, i.e, it does not depends on the observer's frame of reference. The mass used when calculating the gravitational force, via Newton's law, does not change. So in answer to your question: "No, the gravitational force doesn't change in that situation".
I strongly suggest to read this popular article by Lev Okun where he calls the "relativistic mass" a pedagogical virus.
The concept of a so-called relativistic mass which changes with velocity is no longer considered the best interpretation of mass in special relativity. Instead, the invariant/rest mass is used. See here for a discussion. The increase in energy (through momentum) of energy associated with speeding up, however, does increase the extent to which an object contributes to the stress-energy tensor of the system under investigation. Hence, it is a stronger source of gravity.
Danu
  • 16,576
  • 71
  • 110
