When working on the lattice it is easy to define a trivial product state. A state $|\psi\rangle$ is a trivial product state if it admits the following tensor decomposition, \begin{equation} |\psi\rangle=\bigotimes_{i}^N |\psi_i\rangle, \end{equation} where $|\psi_i\rangle$ is the state of a single a lattice site and $N$ is the number of lattice sites. A trivial product state is one with no entanglement since every lattice site is essentially doing its own thing.
This definition works perfectly when our space is a lattice with separate sites, but is there an analogous definition of trivial product state that works well in the continuum without ever using the lattice?
Your lattice apparently has finite size (and we could assume cyclic boundaries for convenience). If you let $N\rightarrow\infty$ but keep finite size the limit is a continuum with cyclic boundaries.
To keep the energy finite in the limit process, each site on the lattice should decrease it's particle number expectation, e.g. we can choose: $$ |\psi_i\rangle = \frac1{\sqrt{1+\frac1N}}\ \big(1+{ \frac{a_i^\dagger}{\small\sqrt N}}\big)\ |0\rangle $$ so a superposition of (mainly) the vacuum and (a little bit of) a single particle state. The total continuum state is then: \begin{align} |\psi\rangle&=\lim_{N\rightarrow\infty}\ \frac1{(1+\frac1N)^{N/2}}\ \otimes_{i}^N \big(1+{ \frac{a_i^\dagger}{\small\sqrt N}}\big)\ |0\rangle \\ &= \frac1{\sqrt e}\ \lim_{N\rightarrow\infty}\ \otimes_{i}^N \big(1+{ \frac{a_i^\dagger}{\small\sqrt N}}\big)\ |0\rangle \end{align}
A mathematical technicality is that we do not have a notation for the continuum limit of the product (like the integral is the continuum limit of a summation) so it is then merely a problem of how to write down the limit in a closed form expression.
You can formally define such a state, but if the Hamiltonian has a term like $|\nabla \phi|^2$ in it, then that state will have an infinite energy. The reason is that a totally unentangled state will have no correlation between spatial regions, including infinitesimally separated ones. See this answer for more details.
11zaq
  • 1,224
