This question is the continuation of a previous SE post of mine. Since I have $4$ questions to object to KDP answer, I decided to write this new post.
To sum things up briefly: we were concerned about the difference between 1. the case where we shine two photons side by side into a metal at a rate of $1$ photon /s, and 2. the case where we shine two photons in a line (that means one after the other) at a rate of $2$ photons/s. In both cases we have the same power of photons involved.
KDP answered that, while the power is the same in both cases, the surface power density will be different from one case to the other (if I understood well).
- My first question is precisely about this surface power density. KDP talks about current (not about surface power density) but I don't quite get the relation between current and surface power density. Current is in A while surface power density is in $\boldsymbol{kg\cdot s^{-3}}$ ?
- My second question is about the area involved in this surface power density. Why are we saying that the surface power density in the first case is half the one of the second case ? Since a photon has no diameter how can we say that two photons coming in side by side occupy an area twice bigger than the area of a single photon ?
- Third question is: how can we experimentally ajust the rate (in photons/s) of photons coming in in a line ? I mean how can we decrease or increase it?
- Last question: can we make converge two photons, exactly at the same time, to a same electron ? For example: if the work function is $\phi$, can we make converge two photons of energy $0.51 \phi $ to one electron and succeed in ejecting it ?
