I've heard my parents saying that the water in earthen pots that are made in winters cools more than a pots that are made in summers. Is this true according to physics? I understand the process of water cooling in a pot , but what is the effect of environment temprature on the pots during manufacturing of pots?
I can think of factors like the density of water is maximum around 4°C ( that's the temperature during winters in Northern India), so when wet pots when placed for drying up in open (before putting then in furnace), as the water molecules evaporate,they expand Just before evaporation, that makes the pores in pots little bigger.
May be I'm wrong, there may be other factors like properties of a particular mud that is used for manufacturing. I want to know what is the scientific explanation for this phenomenon.
Thank You.
Gajjze
  • 173
water cooling in clay pots is caused by evaporation of water that seeps out of tiny pores in the pot, wetting its outside surface. The most likely answer is that the pots fired in winter are more porous than those fired in summer, and support a greater evaporation rate- and hence a greater evaporative cooling effect.
This would make for a very interesting series of experiments designed to test the basic hypothesis, and then to determine exactly where the seasonal effect on porosity after firing comes from!
niels nielsen
  • 99,024
Earthenware cools water by allowing small amounts of it to move through pores then evaporate once it gets to the outside surface, removing heat, thereby cooling the water.
How effective this process is, depends on how porous it is, and that can come from various other factors. It may be that the ambient temperature (winter or summer) where it is made is one such factor. That is, the warmer environment in the summer leads to less pores, while those made in winter are more porous.
Of course, the number of pores, average thickness of each, number density (how many there are in an average volume) all have an affect on the permeability of water, and therefore how heat is transferred, and many other physical and chemical processes are occurring when making these pots. A more accurate answer to your question would be require more information.
joseph h
  • 31,821
