ChatGPT's answer is not wrong, but it does not answer your question. The problem lies in a misunderstanding of what a solution to Einstein's field equations is. In the case of static spherically symmetric spacetime, they are simply linear ordinary differential equations of first and second order, see reference here. Mathematically, a differential equation has an infinite number of solutions. Physically, however, there is only one solution, a function satisfying the equation that also satisfies the corresponding physical boundary conditions, for example, the values of pressure and energy density at a given boundary. Now, if you start from a "universe" consisting only of spacetime, you cannot set any physical boundary conditions, because spacetime is immaterial. When you solve the corresponding differential equations for Schwarzschild vacuum spacetime, you will get the result:
$$g_{tt}(r)~\cdot g_{rr}(r)=1,~~~g_{tt}=1+\frac{C}{r}~.$$
The obove solution apparently depends on an arbitrary constant. How to determine it without the presence of matter is not obvious and has been the subject of some conceptual contortions. Usually the requirement of consistency with Newton's theory of gravity is used. It is
$$g_{tt}(r)=1+2 \frac{\Phi(r)}{c^2}+...=1-\frac{2 G M}{ c^2}\frac{1}{r}+...=1+\frac{C}{r}~.$$
In this way the constant $C$ can be determined as $$-C=\frac{2GM}{c^2}\equiv r_{S}~,$$
the famous Schwarzschild radius.
However, Newton's theory implies the presence of mass, which would contradict the assumption of an empty universe.
