Chiral anomaly is computed very elegantly by Fujikawa method, which is also presented in Section 22.2 of Weinberg QFT textbook volume 2 or wikipedia.
Here, the underlying spacetime is assumed to be $\mathbb{R}^d$ (with $d=4$ in particular), which is contractible and therefore only trivial bundles are possble on it.
However, chiral anomaly leads to (a version) of the Index Theorem as in formula (22.2.49) in the aforementioned Weinberg book, implying that nontrivial topological configurations of the gauge fields are possible.
And this PE post says that nontrivial topologies of the gauge fields on $\mathbb{R}^4$ depend on asymptotic behavior at infinity, so that we can define them on $S^4$, the one-point compactification of $\mathbb{R}^4$.
So...I think there must be (very implicit) assumptions on asymptotic behavior of the gauge fields in the Fujikawa method, but I cannot figure out what those assumptions are and where they apply.
Could anyone please clarify for me?
Keith
  • 1,741
Indeed, from a mathematical standpoint, all the physics that has to do with the global topological terms of gauge theory "on $\mathbb{R}^4$" really happens on $S^4$. So how is it possible that the physicists never talk about $S^4$ yet obtain results related to non-trivial bundles on $S^4$ that are impossible on $\mathbb{R}^4$?
The trick is that you have to view the computations the physicist does on $\mathbb{R}^4$ as this being one of the two patches of a trivialization of the $S^4$ (i.e. one of the poles is "infinity" and this is a patch around the opposite pole), and the other patch is "at infinity" and you assume that there $A=0$ identically, since physical fields vanish at infinity. So all non-trivial phenomena happen in the other patch, and non-triviality of the bundle manifests itself in non-triviality of the transition function between the "normal" patch and the patch at infinity.
The $G$-bundles on $S^4$ can be classified by homotopy classes of maps $S^3 \to G$ (see also this answer of mine), which is essentially the homotopy class of the transition function between the two hemispherical patches, and so the "gauge at infinity" that the physicist sees in their $\mathbb{R}^4$ patch specifies the transition function of bundle, hence a non-trivial bundle on $S^4$ if as $x\to \infty$ the pure gauge $A(x)$ is not related to $A(x) = 0$ by a small gauge transformation: the "boundary at infinity" of the $\mathbb{R}^4$ is a $S^3$, and so $A \to g^{-1}\mathrm{d}g$ gives us a $\pi_3(G)$ that classifies the implicit bundle over $S^4$, and this $g$ is indeed the transition function of the bundle because we initially fixed $A=0$ in the patch at infinity, so the difference between $A=0$ and the value of $A$ in the overlap in the other patch is exactly the effect of the transition function.
ACuriousMind
  • 132,081
