I've heard the example, that work is path dependent. But whether I climb a mountain directly or in serpentines, in the end it's the same amount of work, with the one difference that it takes me longer to climb the serpentines, but in the end I've done the same amount of work against gravity as if I had climbed directly.
When we say that "work is not a state function" we have in mind a thermodynamic system, described by the laws of thermodynamic/statistical physics, rather than a system approximated by a material point - the approximation that underlies the application of the Newton laws (as in the example given in the Q.)
The internal energy of a thermodynamic system (which is manifestly a state function) can be changed on a microscopic level, e.g., via collisions between the molecules of the container with a hot wall, and on macroscopic level - e.g., via changing the shape of the container or other macroscopic parameters. The former is called heat, the latter work. Obviously, the same change of the internal energy can be achieved by different combinations of the quantity of heat and work - e.g., via different paths.
This distinction between heat and work is not applicable on the level where we describe an object as a point-like - where all its energy is the mechanical energy of its global motion. However, once we take into account the internal degrees of freedom, the distinction is meaningful - mounting the mountain directly, in an elevator, or by walking in serpentines cost different amounts of internal energy and results in different thermodynamic states of the object (cheerfully taking photos vs. falling on the ground from tiredness.)
Related: Why does holding something up cost energy while no work is being done?
- 68,984
Work certainly can be path dependent. But, if the work is done by a conservative force then the work is independent of the path.
But whether I climb a mountain directly or in serpentines... I've done the same amount of work against gravity as if I had climbed directly.
This is because gravity is a conservative force.
In equations, a conservative force $\vec F_c$ can be written as: $$ \vec F_c = -\frac{\partial U}{\partial \vec x}\;, $$ where $U(\vec x)$ is a function of space called a potential energy.
The work done by a conservative force is thus: $$ W_{\vec a\to \vec b} = \int_{\vec a}^{\vec b}d\vec {x}\cdot \vec F_c $$ $$ -\int_{\vec a}^{\vec b}d\vec {x}\cdot \frac{\partial U}{\partial \vec x} = U(\vec a) - U(\vec b)\;, $$ which depends only on the endpoints, not the path. I.e., it is independent of the path taken.
- 27,235
The "path" in a thermodynamic process is a path in state space, and can involve changing pressure as well as volume. A change in pressure is analogous to changing the gravitational constant, in which case you will do a different amount of work when you climb the mountain. You can even change gravity back to its original strength once you get to the top so that in both cases you will have reached the same final state, however the amount of work done is still different because of the different paths.
- 1,441
