In a two dimensional conformal field theory I have two sets of generators giving a representation of the Virasoro algebra
$$L_n, \bar{L}_n, n \in \mathbb{Z}$$ $$[L_n,L_n] = (m-n) L_{m+n} + c\frac{m(m^2-1)}{12}\delta_{m+n,0},$$ where $L_n$ is the generator associated to the infinitesimal holomorphic diffeomorphism $z^{n+1}\partial_z$.
The canonical Noether charges (under the condition that $z$ and $\bar{z}$ are complex conjugates are given by (eq. 2.7 in https://arxiv.org/abs/hep-th/9108028 after inserting eq. 3.6 )
$$Q_n = L_n +\bar{L}_n.$$
Usually I would expect that these charges can be exponentiated to give unitaries that implement the conformal transformation. I come however to the following question:
Except for $n = 0$, we have $L_n^\dagger = L_{-n} \neq L_n$, thus the noether charge $Q_n$ is not self-adjoint and exponentiating it does not give a unitary operator. This is probably not surprising for $|n|>1$ because the diffeomorphisms are not globally well-defined so I expect there to be some issue that obstructs to compute unitaries implementing the transformation, in particular since the quantum algebra has a central charge and thus should not implement the classical symmetry (I guess the classical symmetry is broken?). However the same issue arises for $n = 1,-1$ so I don't see how I would construct a unitary implementing a $SL(2,C)$ transformation in such a CFT. However according to the review above they exist (its claimed in eq. 3.21). How do I get their generators? I can in principle compute sth like $L_{-1} + L_1$ which is self adjoint but not obviously related to the diffeo $z^{n+1}\partial_z$. I would expect the noether charge itself already to provide me with the correct generator.
This question is similar to Why do we assume local conformal transformations are symmetries in 2D CFT? but not quite the same I believe.
