Suppose the axes in two coordinate systems S, S' are parallel. Now, suppose I rotate S through some angle $\theta$, and also rotate S' through the same angle $\theta$. It's not clear to me that the rotated axes will remain parallel. In relativity, angles are coordinate dependent. For example, if S and S' are parallel and S' moves at velocity |v|$\hat x$ relative to S, and someone in S' places a bar at an angle of $\theta$ with respect to the axis x', then this angle will not be the same as the angle relative to the x axis. If someone in S then places a bar at an angle $\theta$ with respect to x, then am I correct that this bar won't be parallel to the bar in S' since an observer in S measures the bars at different angles relative to the x axis? However, these bars are just rotated axes, both rotated at the same angle $\theta$, but they're not parallel.
Asked
Active
Viewed 104 times
The Lorentz group contains both ordinary rotations and boosts. Any Lorentz transformation may be written generally in terms of an ordinary rotation and a pure boost: $\Lambda=RL=\tilde{R}\tilde{L}$ So that a Lorentz transformation From some third frame $K$, also parallel to $S$ and $S^\prime$, will be given as: $$\Lambda=RL=\tilde{L}\tilde{R};\;\;\text{For K to S}$$ and: $$\Lambda=R L^\prime=\tilde{R}\tilde{L^\prime};\;\; \text{For K to S}^\prime.$$ Because the $S$ and $S^\prime$ are rotated by the same amount, the same rotation $R$ is used in either case, thus it is obvious that if $S$ and $S^\prime$ were parallel in $K$ then the transformed frames are also parallel.
Albertus Magnus
- 5,652
