There are many questions exploring variations upon the Twin Paradox, but none I have seen seem to resolve this thought experiment.
It is often said that the 1g force we feel on earth due to the surface pushing us in the opposite direction of gravity's pull is indistinguishable from a 1g force applied by a spaceship, and that no experiment can tell a difference. With that in mind, consider the following.
Twins Alice and Bob synchronize clocks. They then accelerate away from Earth with a constant perceived 2g force for the same amount of time, side by side. At this point, both twins agree to go on separate journeys and meet back at earth with carefully timed paths (adjusted for relativistic effects as needed, given that simultaneity is relative).
Both twins will undergo the same forces at the same "times", but from different sources, as follows:
  • while Alice reverses course back towards earth at 2g and then decelerates at 2g to land on the surface, Bob likewise deflects from his course with a force of 2g followed by an opposite force of 2g
  • while Alice then remains on Earth feeling 1g for "6 months" (as shown by her local clock), Bob reduces acceleration to 1g for the same "6 months" relative to his local clock. As we know, accelerating 1g for 1 year should bring Bob to "near" the speed of light relative to something, so 6 months (0.5c) tries to keep both twins still alive when Bob returns
  • after the 6 months, Alice takes another round trip away from earth and back to feel the same acceleration as Bob who is now deflecting course again (carefully changing acceleration twice just as Alice would) to start the journey home
  • this process is repeated one more time so that Bob's deceleration back to Earth is still matched in magnitude by Alice.
This scenario seems to be equivalent to the original Twin Paradox, except we went to great lengths to ensure both twins experienced the same measurable acceleration at all times. And yet, if Bob is younger than Alice when he arrives home, it would seem we just did an experiment where we did in fact distinguish between a normal force from Earth and the accelerating forces by the spaceship, albeit not in the same directions or with any absolute sense of simultaneity.
What detail am I missing that reconciles this or renders it an impossible experiment? Please ELI5 even if a deep mathematical answer is also provided.
Stev0
Indeed, you have proposed such an experiment. The equivalence principle is frequently misunderstood and simply doesn’t apply to the scenario you describe.
The equivalence principle is usually formulated in terms of “local” measurements where “local” is a specific technical term meaning that the measurements are done over a small enough region of space and time that tidal effects are negligible. Another formulation is that it applies to a uniform gravitational field.
Your thought experiment is designed explicitly such that neither condition applies. Because this is not a local experiment and tidal gravity is significant, the equivalence principle is not directly applicable.
Instead, this would simply be calculated using the standard approach of integrating the spacetime interval over the two separate worldlines. No simplification via the equivalence principle can be used.
Dale
  • 117,350
