I was reading the following paper by Landau and Lifshitz on ferromagnetism:
https://www.sciencedirect.com/science/article/abs/pii/B9780080363646500089
In the paper, the following expression is used for the density of the energy of the system (inhomogeneity+anisotropy): $$ 1/2 \alpha s'^2+1/2 \beta (s_x^2+s_y^2) $$ Where $s$ is of course the magnetic moment field, $s'$ is its derivative with respect to $x$, and part of the problem is determining $\alpha/\beta$ (since it gives the square of the width of the intermediate region between magnetic domains). I've used here the slightly confusing notation of the paper, where I believe $1/2a$ means $(1/2)a$, on purpose because I don't know if I'm reading something wrong.
Near the end of page 15 (second page of the PDF) there is a derivation I don't understand. It says:
Blockquote The numerical value of the constant α can be obtained approximately in the following way. The energy $1/2\alpha s'^2$ has its maximal possible value, when $s$ changes its direction after every distance equal to the lattice constant $a$ of the crystal, i.e. when $\boldsymbol{s}'^2 \cong s^2/a^2$ This maximum must be of the order $kT_c$ if $T_c$ is the Curie temperature (k is Boltzmann’s constant). Thus, we find approximately $$ \alpha = kT_c/as^2 $$
There's a few things I don't understand. First of all, it seems to me that the maximum of $s'^2$ should be $(2s)^2/a^2$, since it changes direction completely (therefore the total change is twice its magnitude). But I understand it if it's just an order of magnitude calculation. However, I am then unsure exactly where the Curie temperature comes from, and what's more, the final formula does not seem right to me. My calculation would be: $$ \frac{\alpha s^2}{2 a^2} = kT_c$$ therefore: $$ \alpha = \frac{2 a^2 kT_c}{s^2}$$ But this is not at all the formula they find, unless, I've horribly misread something. In fact their formula doesn't even seem dimensionally correct to me.
As you wrote, the expression is for the energy density, so its dimensions are [Energy / volume]. Meaning that $\alpha$ has dimensions of $[E a^2 s^{-2} a^{-3}] = [E s^{-2} a^{-1}]$ as they have in their formula
