A supernova explosion on the far side of the Sun ejects a mass with approximately the same mass of the Sun directly at the back side of the Sun. If this ejected mass is travelling arbitrarily close to the speed of light, the advance warning of its approach would be arbitrarily close to zero. After it collides with the Sun, there would be a delay of just under 8 minutes before we would become aware of the sudden acceleration of the Sun towards the Earth.
Likewise, if a Sun spot suddenly appeared on the surface of the Sun, it would be approximately 8 minutes before we would would be aware of the Sun spot's appearance as observed from the Earth.
If person A on earth tugs a taught string held by person B located at the sun, would the tug be sensed immediately? (please ignore the obvious mechanical issues such as the earth being in motion, etc.).
KDP
  • 10,288
Tugging on a string launches a tension wave down the string. It moves at the speed of sound in the string, perhaps a kilometer per second. That's fast enough that the wave bounces back and forth, damping down to a constant tension "instantaneously" to human perception, when you pull a string in ordinary circumstances. But the Sun is a long way away...
John Doty
  • 22,119
The tug propagates at the speed of sound in the string, while the gravitational change in the field, propagates at the speed of light. Since the speed of sound in the string is a lot slower than the speed of light, the tug will take a lot longer than 8 minutes to propagate to the other end.
Relativity prohibits the concept of an infinitely rigid object where impulses can travel from one end of the object to the other, instantly, as it would violate the principles of relativity.
KDP
  • 10,288
The "tug" would propagate to the sun at the speed of sound in string. At 100 MPH, that would take 107 years.
