Consider complex scalar field Lagrangian
$$\mathcal{L}=(\partial^\mu\psi)^\dagger(\partial_\mu\psi) - m^2\psi^\dagger\psi\tag{1}$$
Which exhibits $U(1)$-invariance, i.e $\psi\mapsto e^{i\alpha}\psi$. On the other hand, to get a locally $U(1)$-invariant Lagrangian, one introduces a gauge field $A_{\mu}$ and promotes the operator $\partial_{\mu}\mapsto D_{\mu} = \partial_{\mu}+iA_{\mu}$. This leads us to the gauged Lagrangian:
$$\mathcal{L}=(D^\mu\psi)^\dagger(D_\mu\psi)-m^2\psi^\dagger\psi+\frac{1}{4}F_{\mu\nu}F^{\mu\nu}\tag{2}$$
What is the physical motivation behind gauging a global symmetry?
The physical reason to introduce gauge symmetry is a combination of two facts:
  1. We are working in the context of a theory that obeys special relativity (Lorentz invariance) and quantum mechanics
  2. We observe massless spin-1 particles and so want to describe them in our formalism,
  3. We want our formalism to encode local interactions (since, in special relativity, non-local interactions are also not causal).
Point 3 leads us to wanting to use a vector field $A_\mu(x)$ to describe the spin-1 field, since then it is easy to write a Lagrangian with local interactions by multiplying fields at the same spacetime point.
However, in order to describe a masslesss spin-1 particle, there should be 2 propagating degrees of freedom, yet $A_\mu$ has 4 components. Gauge invariance (or gauge redundancy) is introduced to project out the two "unphysical" components of $A_\mu$ in a Lorentz invariant way.
Once we have committed to introducing a gauge symmetry to describe our spin-1 particle, then all its interactions should also obey the gauge symmetry -- otherwise the unphysical components of $A_\mu$ will couple to physical particles. "Gauging a global symmetry" is a method of generating consistent couplings of a spin-1 field to other matter fields in a way that respects the gauge symmetry.
Andrew
  • 58,167
