Recently I came across a video were the origin of inertia was attributed to Sciama’s paper (1953). I have seen only a couple of questions regarding this topic on Stack Physics. Both of them are showing some level of confusion, e.g., it is not clear why Sciama used G=1 at times, but not at other times, or that it predicts a critical density that is out of a factor of two (I am not sure if this is too much, given the conditions of predictions Sciama was working with).
However, despite being seminal, Sciama’s work is still largely unknown and somehow a fringe theory. The confusion around the questions on Stack, or the rarity of questions linked to it, is even more convincing to me that Sciama’s paper (with only 300 citations from ADS) is underrated or has flaws I can’t see.
Why has Sciama’s theory not been experimentally tested? And what would be a possible test for it?
Py-ser
  • 298
There is a discussion of Sciama's paper in Williams and Inan's paper Maxwellian mirages in general relativity, New J. Phys. 23 (2021) 053019:
https://iopscience.iop.org/article/10.1088/1367-2630/abf322/pdf
Sciama's proposal was a linear theory that could only approximate general relativity in some approximations under suitable circumstances in a weak gravitational field. Sciama's proposal for explaining inertia by gravitational induction has not been successfully reproduced in general relativity or in any of the alternatives currently under consideration although attempts were made to do so.
alanf
  • 11,359
  • 16
  • 33
