Suppose we express the phase space volume occupied by all mechanical states $(\mathbf{q},\mathbf{p})$ with energy equal to or less than mechanical energy $E$ as:
\begin{equation}\Phi(E,\lambda)=\int\frac{d^{n}qd^{n}p}{h^n}\Theta(E-H(\mathbf{q},\mathbf{p}));\lambda)\end{equation}
Where $n$ is the degs of freedom, $H$ is the Hamiltonian for the system,$(\mathbf{q},\mathbf{p})$ the coordinates and generalized momentum, $\lambda$ a parameter of $H$, and $h$ has dimensions of action, leaving $\Phi$ dimensionless. Note that the density of states is then simply $\dfrac{\partial\Phi}{\partial E}$.
Suppose the simplest case, a 1-d particle in a box of length $L$. The Hamiltonian is simply $H=\frac{\mathbf{p}^2}{2m}$, and the energy levels:
\begin{equation}E_n=\frac{n²\hbar^2\pi^2}{2mL^2}\end{equation}
So, if $p\leq\frac{n\pi\hbar}{L}$: \begin{equation}\Phi(E)=\int\frac{dqdp}{h}\end{equation}
And 0 otherwise. So,as far as calculating D.O.S goes, seems like I got nowhere. Of course you could just say: \begin{equation}\omega(E)=\int dqdp=h\Phi(E)\end{equation}
But that's pretty circular. How can I get actual results from this definition?
