It is a well-known fact that rotating planets have a flattened spheroidal shape. However, the NASA site says about Haumea:
The fast spin distorts Haumea's shape, making this dwarf planet look like a football.
Haumea rotates especially quickly, and its shape is an ellipsoid with 3 different axes. Does one in fact cause the other? If a planet rotates very quickly, can its shape be distorted to something not symmetrical around the axis of rotation?
It looks counter-intuitive to me. Imagine a thought experiment: we spin up a big planet gradually, while letting it assume hydrostatic equilibrium all the time. How will its shape change until it falls apart? My common sense tells me it will be flattened more and more, and its larger radius will approach infinity. But NASA says that it will assume a different shape at some point.
What gives?
user27542
  • 876
Check out the nice illustrations of Jos Leys The shape of Planet Earth for Ghys’ presentation.
It’s actually an illustration of symmetry breaking. Yes, the problem is symmetric, but this only means that the set of solutions is stable by the symmetry. You can only conclude that an individual solution is symmetric if it is unique. Symmetry breaking therefore arises when you have a multiplicity of solutions.
In your case, the error in your reasoning is to assume that there is only one possible shape for the rotating fluid. The idea is that when it spins sufficiently fast, you get a bifurcation and many different shapes are possible. The set of all the possible shapes is invariant by rotation. Furthermore, paradoxically, the Maclaurin solution which is axisymmetric and which is the one you have in mind that flattens out, ceases to be stable at a finite value of angular momentum.
Note that at even higher rotation rates you can have even less symmetric stable configurations (pear shaped, etc.).
Hope this helps.
LPZ
  • 17,715
  • 36
