Electric current is the rate of flow of charges (electrons) or the rate of flow of positive charge. Okay, I get it. But here's my question. The electron flows in the wire and then the current flows in the opposite direction of it. What is that thing that is flowing in the opposite direction of the electrons? Protons don't flow, so what is that thing? What is that thing that we are feeling as shock and making electric things run? In the AC, the electrons don't even flow, they just drag back and forth. I am completely confused.
VoulKons
  • 16,825
  • 45
  • 73
In ordinary conductors, the physical thing that flows is electronic charge. This is due to the fact that conductors have loosely bound electrons that are essentially free to move about the crystalline lattice. The current density in an ohmic medium can be defined as $\vec J=\vec v\rho$, where $\rho$ is the charge density and $\vec v$ is the velocity of "flow". Thus, in this definition there is an analogy to the flow of fluids. As Jon Custer notes in the comments, it is a matter of convention that one may regard any negative charge as a positive charge flowing in the opposite direction, this is why current in schematic diagrams, or "conventional current" flows in opposition to the actual physical flow of electrons.
More precisely: the electrons flow in the wire and the current density points in the opposite direction.
While it is common to say that current flows, it is somewhat inaccurate. Since you are struggling with this, it may help to say things precisely.
A current consists of some moving charged particles. Those particles are called charge carriers. The charge carriers move, so that is a flow. The current density is a vector defined by $\vec j=\rho \vec v$ where $\rho$ is the charge density of the charge carriers and $\vec v$ is their velocity.
Only the electrons are flowing in a metal. The current density points in the opposite direction of the flow of electrons.
That is current density. What exactly is flowing is irrelevant. In a wire the charge carriers (the thing that flows) are negative. In your tissues there are both positive and negative charge carriers. So the charge carriers can be negative, positive, or both. It doesn’t matter.
Dale
  • 117,350
