In transmission cables, why does power loss increase when length of conductor is increased? According to the formulas V=IR and P=I²R, When we increase the length, the resistance increases, while the potential difference is same, the power loss decreases as current decreases. So why does the increase in length of wire, hence the increase in resistance, cause the transmission line loss? The power should decrease as per my understanding.
Since you have that $$P=I^2R,$$ it is reasonable to think that because an increase in resistance leads to a drop in current that it might be possible this could happen in a way that doesn't always lead to power loss, the change could be such that there is break even, or even less power loss in higher resistance lines, however, the reality of this is not so in practical applications. In real life practical applications, the current on the transmission lines is largely determined by the consumer power demand and not that of the line resistance, so you get in general, an increases in ohmic losses for an increase in transmission line length. A fact that power plant engineers mitigate for by using AC power transmitting at high voltages.
- 5,652
The power you send in on the source side: $P_{in}=U \cdot I $ The current that flows through the line causes a voltage drop $U_{line}=R_{line} \cdot I$ . Thus the power you get out is: $P_{out}=U_{out} \cdot I = (U-U_{line}) \cdot I = U \cdot I - U_{line} \cdot I = P_{in} - I^2 R_{line}$
So your Power Budget:
- You send in $P_{in} = U \cdot I $
- Your loss $P_{loss} = I^2 R $
- You get out: $P_{out}=P_{in}-P_{loss}$
One easy way to make the loss smaller is to use a higher voltage. With a higher voltage you need a lower current for the same transmitted power. An as the loss is poportional to $I^2$ it is reduced. But as the voltage gets higher you need to make sure the wires are spaced far apart or else you get sparks over your line. This is why high power transmission lines look the way that they are.
- 226
