Which type of potentials lead to Kepler's second law "same area in same time"?
$$dA=\frac{1}{2} \vec{r} \times \vec{dr}.$$
$$\frac{dA}{dt}=c=\vec{r} \times \frac{\vec{dr}}{dt}=\vec{r} \times \dot{\vec{r}}. $$
Differentiating both sides we can get a statement on the force field
$\dot{\vec{r}} \times \ddot{\vec{r}}=0, m\dot{\vec{r}} \times m\ddot{\vec{r}}=0,m\ddot{\vec{r}} \times m\dddot{\vec{r}}=0$
I do not know how to proceed from here, however, I believe we should be able to say something on the potential field now since we have a statement on the force field. Perhaps something along the lines of
$\begin{bmatrix} F_x \\ F_y \\ F_z \end{bmatrix} \times \begin{bmatrix} \frac{d}{dt}F_x \\ \frac{d}{dt} F_y \\ \frac{d}{dt} F_z \end{bmatrix} = \begin{bmatrix} \frac{\partial \phi}{\partial x} \\ \frac{\partial \phi}{\partial y}\\ \frac{\partial \phi}{\partial z} \end{bmatrix} \times \begin{bmatrix} \frac{d}{dt}\frac{\partial \phi}{\partial x} \\ \frac{d}{dt} \frac{\partial \phi}{\partial y} \\ \frac{d}{dt} \frac{\partial \phi}{\partial z} \end{bmatrix} =0 $
Edit:
It was brought to my attention that the identity for dA should include a norm $dA=\frac{1}{2}||\vec{r} \times \vec{dr}||$
Applying the same derivative process
$\frac{d^2A}{dt^2}=\frac{1}{2}\frac{1}{||(\vec{r} \times \dot{\vec{r}}||} \frac{d}{dt}(\vec{r} \times \dot{\vec{r}})\cdot (\vec{r} \times \dot{\vec{r}})$
$\frac{d^2A}{dt^2}=\frac{1}{2||(\vec{r} \times \dot{\vec{r}}||} (\dot{\vec{r}} \times \dot{\vec{r}} + \vec{r} \times \ddot{\vec{r}}) \cdot (\vec{r} \times \dot{\vec{r}})=\frac{1}{2||(\vec{r} \times \dot{\vec{r}}||} (\vec{r} \times \ddot{\vec{r}}) \cdot (\vec{r} \times \dot{\vec{r}})=0$
$(\vec{r} \times \ddot{\vec{r}}) \perp (\vec{r} \times \dot{\vec{r}})$
16π Cent
  • 141
Kepler's second law is just conservation of angular momentum. Angular momentum is conserved for any spherically symmetric potential.
In particular, as you note, the geometrical interpretation of the cross product implies that as the orbit crosses some differential $\mathrm{d}\vec r$, the differential area that it sweeps is $$\mathrm{d}\vec A=\frac{1}{2}\vec r\times\mathrm{d}\vec r$$ (where I let $\vec A$ be a vector area, but that's not important). The rate at which area is swept is then $$\frac{\mathrm{d}\vec A}{\mathrm{d}t} = \frac{1}{2}\vec{r}\times\dot{\vec{r}} = \frac{\vec L}{2},$$ where $\vec L$ is the orbital angular momentum (per mass) about $\vec r=0$. Kepler's second law amounts to saying that $\mathrm{d}^2\vec A/\mathrm{d}t^2=0$, which is thus the same as saying that angular momentum is conserved.
There are fundamental reasons angular momentum conservation is connected to spherical symmetry (see Noether's theorem). But we can also just explicitly note that $$\frac{\mathrm{d}^2\vec A}{\mathrm{d}t^2}=\frac{1}{2}\vec r\times\ddot{\vec r}$$ (since $\dot{\vec r}\times\dot{\vec r}=0$), so Kepler's second law means $\vec r\times\ddot{\vec r}=0$, i.e., that the force $\ddot{\vec r}$ is parallel to the position vector $\vec r$. If the force is the gradient of a potential $\phi$, then this means $\phi$ can only vary with respect to $|\vec r|$, i.e. it must be spherically symmetric.
Sten
  • 7,910
I think your procedure is not completely correct... When deriving the Kepler law you have to derive the product as: \begin{eqnarray} \frac{dA}{dt} &=& \frac{1}{2}\vec{r}\wedge\dot{\vec{r}} = c \\ \frac{d^2A}{dt^2} &=& \frac{1}{2}(\dot{\vec{r}} \wedge \dot{\vec{r}} + \vec{r} \wedge \ddot{\vec{r}}) = 0. \end{eqnarray}
The first term is null due to the properties of vectorial product and then, the second Kepler's law says that the movement is governed by a central force perpendicular to the movement, i.e. $\vec{r} \perp \ddot{\vec{r}}$, which is other manner to say that the total angular momentum is conserved, and the movement is contained on a plane. By this way, we do not have any information of the potential.
Nevertheless, I appreciate your physical intuition because it points out to a very interesting equation in physics: the Binet equation. This equation relates the potentials with the trajectory of the orbits. One can feed the equation with a polar-parametrized curve and compute what potential can produce the orbit, or one can put a given potential and solve it for, obtaining the family of curves the potential can handle. The derivation on Wikipedia is easy to understand for your purpose: https://en.wikipedia.org/wiki/Binet_equation
When solving the Binet equation for the Newtonian potential, one obtains the 3 family of curves we observe in the solar system: elliptical, parabolic and hyperbolic, which corresponds with the conic sections. But when varying slightly the Newton potential $V(r) = G\frac{M}{r^{1+\epsilon}}$ with $\epsilon << 1$ the orbits are open instead of closed, in contradiction with Kepler 1st Law. Furthermore, the Bertrand's theorem states that the only two potentials which orbits are closed are the Newtonian and the harmonic potential. (see https://en.wikipedia.org/wiki/Bertrand%27s_theorem)
In conclusion, Kepler's Second Law is applicable to any two-body gravitational system where total angular momentum is conserved but is not linked to a specific gravitational potential. Instead, there exists a connection between trajectories and potential: between the Kepler's First Law and the Newtonian potential.
xray0
  • 540
T. ssP
  • 543
starting with
\begin{align*} &\frac{d\,\vec{p}}{dt}=\vec{F}\\ &\vec{L}=\vec{r}\times\vec{p} \end{align*} where $~\vec{L}~$ is the angular momentum and $~\vec{p}=m\vec{\dot{r}}~$ is the linear momentum
obtain the time derivative of the angular momentum \begin{align*} &\frac{d\vec L}{dt}=\underbrace{\vec{\dot{r}}\times\vec{p}}_{=\vec{0}}+\vec{r}\times\vec{\dot{p}}=\vec{r}\times\vec{F} \end{align*}
hence, the angular momentum is conserved $~\left(\frac{d\vec L}{dt}=0\right)~$ only if the force $~\vec{F}~$ is central force: \begin{align*} &\vec{F}=f(r)\,\frac{\vec{r}}{|\vec{r}|}\quad\Rightarrow\\ &\frac{d\vec{L}}{dt}=\vec{r}\times\vec{\dot{r}}=\frac{1}{m}\left(\vec{r}\times f(r)\,\frac{\vec{r}}{|\vec{r}|}\right)=\vec{0} \end{align*}
with \begin{align*} &\frac{d\vec A}{dt}=\frac{1}{2}\left(\vec{r}\times\vec{\dot{r}}\right)=\frac{1}{2}\frac{d\vec{L}}{dt}\quad,\Rightarrow \vec{A}=\frac{1}{2}\vec{L} \end{align*}
the potential is \begin{align*} U(r)=-\int f(r)\,dr=-\int \frac{m\,M_s\,G}{r^2}\,dr=\frac{m\,M_s\,G}{r} \end{align*} with $~f(r)~$ the gravitation force between the planet and the sun
Eli
  • 13,829
