If a mass is attached to a spring(hanging from a wall) with spring constant $k$, causing an expansion $x$, then the potential energy stored by the spring is $\frac{1}{2}kx^2$. However, the potential energy stored by the spring is just the potential difference of the mass caused by its descent, isn't it? So why isn't the potential difference equal to $mgx$, which in turn is equal to $kx^2$, since $mg$=$kx$?
No, the two potential energies are quite independent of each other. Therefore it doesn't make sense to equate them.
- The potential energy of the mass due to its position in the
gravitational field of the earth is $mgx$.
This energy part is positive or negative, depending on whether mass is ascended ($x>0$) or descended ($x<0$). - The potential energy of the spring due its compression or expansion is $\frac{1}{2}kx^2$.
This energy part is positive both when the spring is compressed ($x<0$) and when it is expanded ($x>0$).
Rather than equating these two potential energies, it makes more sense to add them, i.e. to calculate the total potential energy. $$E_\text{pot}=mgx+\frac{1}{2}kx^2$$
- 42,352
Assuming $x > 0$ lies in the upward direction, the spring is ideal (with no damping) and you release the mass from the spring's unstretched position ($x = 0$), it would keep oscillating up and down between $x = 0$ and $x = -2mg/k$, never settling at $x_0 = -mg/k$. This is because part of the initial gravitational potential energy is converted into kinetic energy.
In order for the mass to settle at $x = x_0$, there either needs to be a damping mechanism dissipating $\frac12mg|x_0|$ of energy as heat, or you have to manually intervene and do work equal to $-\frac12mg|x_0|$. In either scenario, mechanical energy is not conserved, so you cannot use conservation of energy to determine the equilibrium position.
- 14,100
