From an online lecture, I heard that $d$ orbitals cause metals to have a peak in their reflectivity curve at some wavelength. This is generally the case for most metals. However, the peak lies mostly in the ultraviolet region which makes them still appear silver-greyish. But for copper and gold this peak lies in the blue/violet region, which makes them appear orange or yellow. For gold, the shift of the peak is caused by special relativity due to the great mass of the nucleus.
My underlying question is, why mercury (and all following metals in the transisiton metal group) is not also golden, as it also has $d$ orbitals and is heavier than gold and therefore should have a more shifted peak.
With almost the same logic: Why aren’t transition metals before copper in the PSE also colored, when they have $d$ orbitals?
I could not find a lot of sources to this topic to compare with, so I might have some errors in my reasoning. Feel free to correct them.
- 167
Gold metal conduction (and the associated reflectivity) is from hybridized orbitals of the outer shell, which is 6S electrons only. There's no free-to-respond competition from non-S-orbital P, D, or F electrons. The metallic bond in a lump of gold is composed of these mobile S electrons, and it is these which make the metal reflective.
Those S electrons have no orbital angular momentum, so penetrate the high-Z nucleus. Potential energy when IN the nucleus is low so kinetic energy is high (the sum is a constant). As a result, relativistic mass increase makes them "spend more time there" so to speak. The same mass increase makes them less responsive to the electric field of light, thus less reflective than would otherwise be the case.
Cesium is slightly lower-Z but also has one 6S-electron dominating. It, too, has some color.
- 10,853
