-1
In special relativity, an object (a box, perhaps) travelling at 0.5c relative to us, if it thinks it's 1lightsecond long in its own reference frame, will look 0.866 lightseconds long to us.
My question can be phrased in a few ways:
If that box stops in front of us - it decelerates from 0.5c in our ref frame to 0 in our ref frame - will it look 1 light second long to us?
Conversely, imagine a box that is 1 light second long in our reference frame and stops - and then it starts accelerating, and accelerates to 0.5c in our reference frame and then stops accelerating, it stays at 0.5c. Is it still 1 light second long in its own reference frame, or has it seen itself change length?
TKoL
  • 156
That depends on the question: In which frame did the parts of the box accelerate simultaneously?
Case 1: All parts of the box are being accelerated simultaneously in the rest frame of the box. This means its points will not be accelerated simultaneously in our frame (due to Relativity of simultaneity). The box parts more to the left will stop first, then the parts to the right of the box will stop later, leading to an expansion in the direction of motion, so that its length indeed becomes 1 lightsecond in our frame.
Case 2: All parts of the box are being accelerated simultaneously in our frame. What happens afterwards depends on the material constitution of the box, and the strength of the acceleration. a) If the box's material is very weak, it will be compressed by the simultaneous acceleration in our frame, the box will be broken and/or squeezed, so the length stays at 0.866 lightseconds at the time it stops, or b) the box's material is strong enough to stay intact, thus it will expand as its velocity decreases, because the forces that hold its material together tend to restore its proper length of 1 lightsecond.
Of course, there are many other cases and outcomes depending on the acceleration profile you choose.....
Batiatus
  • 604
This is not a relativity question; it is an elementary math question!
The reason it's not a relativity question is that you're asking what happens in just one frame (namely the one you call "ours"). Relativity is for predicting how measurements in one frame relate to measurements in another.
So: There are forces acting on both ends of the box causing it to decelerate. The new length could be anything depending on the nature of those forces. They might cause the box to stretch, or they might cause it to squish. To determine what happens, you need to specify the time path of the acceleration at the left and right ends of the box.
Say that the acceleration of the left and right ends are given by $a_L(t)$ and $a_R(t)$ at time $t$, where $t$ ranges from (say) $0$ to $1$. At time $0$, the distance between the left and right ends is (by your assumption) 1 light second. Now use calculus to compute the distance at time 1.
For example, if $a_L$ and $a_R$ are the same function, then the box length (quite obviously) cannot change at all.
Change the functions $a_L$ and $a_R$, and you'll get a different answer.
If you did everything in another frame, you'd have to use different acceleration functions. In particular, if $a_L$ and $a_R$ are the same function (so that the box length doesn't change during deceleration in your frame) then in another frame they will typically NOT be the same function (because in the other frame, one end of the box will start moving before the other). But you can bypass those computations, because relativity predicts the new length of the box in the other frame, which must turn out to be (in your example) .866 times whatever the new length is in our own frame.
But your question is only about our own frame, where the question comes down to: A box of given length is moving. It decelerates. What is its new length? And the answer comes down to: How does the left side decelerate? How does the right side decelerate? Make your assumptions and calculus gives you the answer.
WillO
  • 18,387
