I am currently an undergraduate taking a course on Newtonian mechanics. The lecturer defines a force to be conservative if there exists a scalar function (we call it potential function), say $V(x,y,z)$, such that the force $$\mathbf{F}=-\Big(\frac{\partial V}{\partial x}\mathbf{\hat i}+\frac{\partial V}{\partial y}\mathbf{\hat j}+\frac{\partial V}{\partial z}\mathbf{\hat k}\Big).$$ Then the lecturer told us that whenever you see an expression of $\mathbf{F}$ which depends on velocity $\mathbf{v}$, then this force must be non-conservative. Then I asked why, because I think in some scenario $\mathbf{v}$ can be expressed solely in terms of an object's position vector $\mathbf{r}$, but the response was not clear. Could anyone comment on the lecturer's statement and explain why?
I know there are similar questions on this community, but I has not found a rigorous proof to, say, how to show that $\mathbf{F}=A\mathbf{v}$, where $A$ is a non-zero constant, is not conservative? Thank you.
IncredibleSimon
  • 195
A force is not conservative if work depends on the path taken by the particles. Work is defined as
$$W = \int_A^B \vec{F}\cdot d\vec{\ell}$$
Now you see that if $\vec{F}$ depends on the velocity $\vec{v}$, you will not have the same integral for $W$ depending on the path you take.
You are stating that $\vec{v}$ can depend solely on $\vec{r}$. This is true, but the changes in velocity $\vec{v}$ of the particle moving along the path $A\to B$ is generated by the forces acting on it, such that it must be obtained from solving the equations of motions. For forces dependent in $\vec{v}$ it is thus impossible to express the velocity solely in term of $\vec{r}$ by solving the second law of dynamics ($m\dot{\vec{v}}=\vec{F}(\vec{v})$), such that you can never find a path independent expression for $W$. You can think of simple examples as motion with friction e.g. $\vec{F}=-k\vec{v}$. In that case, you will obtain $|\vec{v}| \propto e^{\frac{k}{m}t}$, such that $W$ will depend on the path (the longer the path, the greater the time $t$ and the greater the work!).
Léo Vacher
  • 1,154
