I've avoided the use of the word "force" here, because I think that's not the right model, but correct me if I'm wrong. In describing a wave, the wave has peaks and troughs of equal distance, ceteris paribus - what is the limiting circumstance that causes the wave to return to the baseline from either direction, instead of spinning off into infinity?
What is the circumstance that limits the amplitude of a wave?
The intensity (power per unit of area) of the wave is proportional to the square of its amplitude. So the amplitude of the wave is limited by the power that the source can produce.
For EM waves propagating in a material medium (as opposed to in vacuum), high amplitude waves may excite nonlinear behavior in the material; for example, arcing or burning, and this may limit the magnitude of a wave that can propagate through the material without high losses.
This is a different question entirely. If you think of a vibrational wave on a metal spring, there is a restoring force such that the greater the displacement of the spring from the neutral point, the greater the force pulling it back toward neutral. This part of your question seems to be asking what plays that role in an EM wave.
In the EM wave, what happens is that the electric and magnetic fields exchange energy. Changing electric field produces a magnetic field and changing magnetic field produces an electric field. Rather than try to make this clear in my own words, I'll quote Feynman:
How can this bundle of electric and magnetic fields maintain itself? The answer is: by the combined effects of the Faraday law, ∇×E=−∂B/∂t, and the new term of Maxwell, c2∇×B=∂E/∂t. They cannot help maintaining themselves. Suppose the magnetic field were to disappear. There would be a changing magnetic field which would produce an electric field. If this electric field tries to go away, the changing electric field would create a magnetic field back again. So by a perpetual interplay—by the swishing back and forth from one field to the other—they must go on forever.
Similarly to Feynman's argument here, if (for example) the electric field were to increase indefinitely, then that changing magnetic field would also produce an increased magnetic field strength. But the energy for that would have to come from somewhere --- it would have to draw energy out of the electric field for that to happen --- and the excursion of the electric field is limited by its energy being drawn away to form the magnetic field for the next cycle of the wave.
- 29,651
A mechanical wave - be it at the boundary of two media such as water-air or in a medium such as a bell - is always bound to the "constitution" of the media. This includes the elasticity or viscosity of the solid or liquid. If the cohesive forces are exceeded, the amplitude of the wave - which is proportional to the force acting on it - is destroyed. In addition to the magnitude of the force, the frequency of the impact also plays a role. This is not the case with an impact, but there are plenty of examples where the force also acts periodically.
The story is completely different for electromagnetic waves. Here, the amplitude is associated with the energy of the wave. The EM wave has a frequency and two components that are perpendicular to each other in a vacuum, consisting of the electric and magnetic components. However, the expansion of these components is assumed to be infinitely extended.
- 10,980
